I just put my bottom end together last night (crank only right now) and dropped in my cam bearings... damn that wasn't easy... Since I'm using a 350 install tool and the 350 bearings in a 3400 block, the install die is just ever-so slightly over-sized for the final bearing install diameter (the mains are a bit smaller than a 350 so when installed it compresses the bearing just a little bit more) and I forgot to sand it down before doing the first bearing, so getting the die back out and not causing any damage was a chore... after that I took some 500 grit to it just to bring down the little machine lines on the die and that helped get the rest in... I also had issues with the main support on the install tool, its held in place with a roll pin and that bent and broke after I got the last bearing in... Cheap Ebay cam bearing install tools FTL!!... But in the end with the cam back in I could see the cam journals were 100% supported by bearing now, and not just the middle's. And hopefully these bearings last longer than the sealed power ones did.
Today is piston cleaning at lunch time at work, and then I can hopefully get those in soon so I can then do the cam and lifters and chain, and then be done with the short block and wrap that up... Then I can concentrate on the porting which makes a MESS... That's why I want to get all the parts in the motor that need to stay clean. I did one head already and with all my parts covered I still had to spend a little extra time cleaning them... so Its time to just get them in and out of the mess.
I still have a trans to inspect/freshen after this...
I also just dropped 250 on MLS headgaskets and a crank scraper... MONEY PITS!!! lol
Pics later this week maybe.
Gotta go take down some trees tomorrow... Heating my garage isn't free, labor wise... But the wood is
If I help my father-inlaw take down trees for friends he said I can have all the wood I want... The latest guy wanted about 4-5 cord of wood removed from his property... awesome!
