build in progress
  • #16
    Get some exhaust clips. Just sounds clackity with that camera under the hood.
    Have you tuned it yet for the cam?
    • #17
      thats the best i can get camera wise..still gotta finish the exhaust tho its just an open downpipe, gotta get it tuned still, i literally jut got it running the night before
      00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
      99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
      • #18
        Ah. Well update the thread with progress and more pics! Keep up the work!
        • #19
          2000 3400 grand am with a custom turbo and a stage 3 turbo cam
          got a w.o.t vid with the stage 3 turbo cam from the store here, i still got to get it tuned...this is 9 pounds of boost
          • #20
            I can't wait to install my nitrous... Mine will sound like that
            • #21
              all those mods? a WOT video, and you don't have it tuned yet? Seems pretty damn stupid to me?
              • #22
                not tuned...meaning i gotta do a fine tune..its just safe right now...nothing blowing up or going anywhere...
                • #23
                  ahhh i see.........well decent build so far, what do you have for suspension to help get it to the ground, and you have an upgraded 45 tranny right?
                  • #24
                    as for suspension mods...all ive got is lowering springs...havent done anything with suspension really...and the 4t45 i got in there is stock..i just uppped the line pressure...so far shes holding and ive had it up to 15 pounds of boost...just a few times and i launched it and it held its ground...(crosses fingers)
