thats another thing, didn't you say it was on the way out? i wouldn't be suprised ifyou found 5-10 or more hp in a trans bluid if its really slipping as bad as you say
My 99 Cruiser
So you're just using all 3400 parts, you didn't do a top end swap?
Also, I was wondering if you could tell me where you buy injectors from...I ran a search here and in the store and didn't come up with anything. I assume you got them from somewhere else?
what's your FDR? looking at the speeds, it looks like you have a 3.6XX FDR and ran it up in second gear, then shifted to 3rd. either way, what rpm did you start/finish the pull?
Dave--have you dynoed the car since you swaped to the 3.61 tranny? be interesting to see if the power band changes at all and how much power/torque you lost. you should loose ~8.3% acceleration/power going off of the math (252HP, 239TQ). however, now you are using the flat torque curve to accelerate. so even with a "power" reduction, the combonation is more efficient. --i think i sad that right...Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Well, if he has a 3.29 FDR (which came stock in the GAGT), 6000rpm is good for about 85mph.....so I'm estimating 3.69 gears.
I'm still himming and hawing between the 1393 and 1280 grinds with my 3.42 gears.Matt
which cam did he use?3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
just what i wanted to hear. thanks man3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
can we get a video, i wanna know how it sounds
oh shit, even that, i would have imagined you would have fixed that. so why you still got the sig of the car? lol
