Originally posted by Tofuball
View Post
1986 Volkwagen Vanagon
Wow, pretty positive response, I wasn't expecting this much interest
I guess I'll get some more in-depth pictures later. Some problems I'm having with the 3.4L are I can't get some of those stupid rocker arms adjusted right so they don't make clacking noises, so I think I might have a collapsed lifter or something. Piston engines aren't exactly my specialty.
I tried adjusting them per the Hanes manual (turn crank to a certain position, tighten till pushrod wont rotate, tighten again by a set amount)
All of them clicked and clacked pretty badly from that.
Then I tried adjusting them the way I used to do my mustang (got a spare valve cover, cut a hole in the top, and adjusted all the rockers (with the engine on) based on sound)
That fixed it for a few minutes, but then one of them just got really noisy and the rest got a little noisy.
Also my coil is toast, (I have to keep dwell set really low at 1.9ms so I can even make it to 3800RPM, and I still get tach spikes all over the place (Mostly at 2400RPM)) so I got a Crane Cams Fireball Hi-6 w/ an L92 coil I'm going to swap in for the time being to see what that fixes.
Originally posted by The_Raven View PostThe DOHC heads are taller than thier pushrod counter parts, still not as high as the intake, but tall, none the less.
Originally posted by 86euro View PostVery coolI also like the rear tube bumper (the actual bumper, not the x-pipe. Well, that's cool too).
Update:
I just put a Crane Cams Fireball Hi-6 on and it made a pretty big difference!
The idle is worlds stronger now, I can probably tune it a bit leaner throughout as well.
I bet I'll get a pretty significant MPG gain total.
So for those of you with dizzys, I recommend it.
Also, I have a friend who's giving me his 95 Lumina for parts, so I asked some questions about parts interchange in this thread:
Note: I had to take the fan off the alternator to make it fit w/o hitting the rear wall of the van. Also the A/C compressor is pressed up pretty firmly against the rear wall of the van, so if I ever turn it on I'll be out an A/C clutch. I need to cut and weld some space in back there, and some more support.
That is awesome. I know a very little about VW's from the guys I used to work with. I know much more about the GM V6's, though not as much as a lot of the guys on here. What I do love is engine swaps. This is wicked cool. Turbo it or something! Use a Fiero driveline, or any other GM automatic or manual transmission that bolts to these engines. That would be a lot better reliability wise.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Originally posted by Tofuball View PostSo, I took off my engine cover and drove around a bit.
Either my engine has some mechanical problem, or these 60 degree engines are just LOUD.
Mine clicks like crazy. Is that normal for these engines?
Originally posted by ForcedFirebird View PostLike injector click, or valvetrain tap? My injectors are loud, I have 24# Densos.
Originally posted by whitelightnin04MC View PostAwesome, another marylander.
That's a pretty awesome VW.
These engines can be loud, and still be alright. I don't think you can adjust the valves in these things anyways. I had a 3.1 MPFI that was ridiculous loud. It was fine, but it was just a clatterbox. My soon to be ex-wife has our '99 Lumina 3100, and it's noisy at cold startup, too. I wouldn't worry about it.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Originally posted by DEI37 View PostThese engines can be loud, and still be alright. I don't think you can adjust the valves in these things anyways. I had a 3.1 MPFI that was ridiculous loud. It was fine, but it was just a clatterbox. My soon to be ex-wife has our '99 Lumina 3100, and it's noisy at cold startup, too. I wouldn't worry about it.
Then what kinds of knocking sounds should I worry about? :P
Or should I reserve the worrying to the grinding or banging?
Originally posted by whitelightnin04MC View PostFort Washington/Oxon Hill area.
My fiancee is a VW fanatic. She drives the new GTI MkV 2.0T
I've tried adjusting it three times now without it working
