4T60-E and a 3800?
  • 4T60-E and a 3800?
    Hey guys this is alittle off the wall but, I asked this gut why he wanted to swap out a 96' 3.4 dohc for a 3800 series 2. I think its a waste of money and way to go the way of the sheep (I feel). But he said the old tranny would bolt up, is this true? 60 degree to 90 degree I don't think it will work.
    same pattern
    dunno why he would get rid of a 3.4 for a 3.8 tho
      Re: 4T60-E and a 3800?
      Originally posted by Lyle's GTP
      wanted to swap out a 96' 3.4 dohc for a 3800 series 2...he said the old tranny would bolt up, is this true? 60 degree to 90 degree I don't think it will work.
      The 4T60-E will for sure work on the 3800 motors - I've got an '87 Bonne with an older 3.8 which has the 4T60 transaxle, the exact same one that's in both of my Celebrity wagons (2.8 & 3.1 motors).
      Even FURTHER off topic, but just for informational purposes, even the NORTHSTAR V8, the all-aluminum 90 degree FWD (exclusively so until recently) Cadillac V8 has the same bellhousing as the 660s. Check the picture I've enclosed. You'll notice the familiar steep sides and flat top to the bellhousing. The biggest difference is the big hole you'll note between the bellhousing area and the lifter galley (well, what WOULD be the lifter galley if it HAD lifters!) - that's where the STARTER goes. Dealerships quote something awful like 6 or 8 hours to change the starter - gotta pull the intake!
      SCREECH
      1976 Olds Cutlass Supreme Brougham, 468ci BBC
      1990 Chev Celebrity Eurosport Wagon - undergoing 3.4/5-speed conversion
      1987 Chev Celebrity Eurosport Wagon - beater
        Hey cool you have a 76' cutlass supreme brougham. My buddy has a 77' black w/T-tops. It's pimpin'. He dropped a Olds 425 into his though, I guess 77' was a bad year for power.
        Lyle
