Hey Everyone,
I am Very happy to say that our Performance Shop sells BRAND NEW (Not re-manufactured from cores) performance injectors for the OBD I or 91' to 93' 3.4 DOHC. They feature very high craftsmanship and we have them made with LBS rating lazer etched on the side. They look as good as they work too!
They feature:
- High Ohms resistance @ 14 ohms
- Available in 21 (stock), 23, 24, 26, and 30 lbs./hr flow rating
- Perfectly balanced, 100% Bench flowed and MATCHED to +/- 1% of the flow rating
- Precision ground from TOP QUALITY Billet steel
- Super fine, wide angle spray pattern to aprox. 130 Micron diameter fuel droplets ( for MAX fuel atomization for better engine efficiency, throttle response, and increased power)
- anti-plugging vapor cap eliminates a chance of any carbon build up.
- Injectors have a Low-mass internal precision ground needle and a HIGH strength fuel pressure spring that have a MUCH faster response time and a VERY wide Dynamic range then stock or stock replacement units
We sell the injectors WITH new Injector O-rings too!
I have these injectors in my own GP 3.4 DOHC and I have to say I'm VERY impressed! These top other injectors I have installed just to see the difference, I honestly can't believe HOW SMOOTH the engine runs!!!
I HIGHLY recommend them for someone replacing there factory ones,
THEY WON'T BE DISAPPOINTED!!!
They come with a 30 day warranty against ANY factory defects.
We sell them for $68.85 US each plus shipping
NOTE: I can have Injectors made for other engine applications too.
BEST REGARDS TOO ALL HERE,
David Hayes
President of
Hayes Performance Plus
They feature:
David Hayes
President of
