6/6 cam timing help!
  • #31
    Set number piston like I showed you and put the tool on it and set both at "0" .
    Since you have the 96, you might need to set the exhaust at +4* and the intake at ZERO.
    • #32
      That no start could be LIM/uim gasket sucking in air causing it to not only fail to start, but also cause that popping through the intake. I at first thought it was due to timing be off (the popping through intake) .
      • #33
        any update on this? i have a 91 w/ 96 engine (lim/uim are still 91, but everything else is 96). i also have a set of cam carriers from a 92. should i use them and time it to 6/6 or use the 96 carriers to 6/2?
        91 GTP HM-284 GONE
        96 Special Edition LQ1/4T60E GONE
        98 Spawn of Satan (L67 Regal)
        87 V10 SM-465/Mild 350
        06 Cobalt SS/SC GONE
        • #34
          well i was thinking about putting a new timing belt on on my car and doing the 6/6 timieng setup but After reading this im little leary, i dont want a rough idel ne thing like that, but i do want the extra low end power and , im not sure about the how lock ring thing i read on here somewhere where the rear cam carr has to come off to get the lock ring out, plus i dont have the falt hold down tool
          1997 Chevrolet Camaro 30th Anniversary 5Speed.
          3800 V6 (i know its not a 60degree)
          stock for now
          1993 Special Edtion/GTP
          3.4 DOHC V6 LQ1 SOLD!
          CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
          180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
          VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
          • #35
            6/6 has a perfect idle.
            • #36
              started my own topic so i erased my comment
              91 GTP HM-284 GONE
              • #37
                OK I just read through this whole thing and watched the video by Ken and Now I dont know what to do.. I know I have to change my belt and I was just going to go with a stock setting and then I read up on the 6/6 and now after reading through this I think I am going to go back to stock, But now what is stock? 0/0 or 0/4* Shit I dont know. Gawd these forum discussions can sometimes be more of a hinderence then a help.
                Do we have a confirmation on if the 6/6 works on the 96 Engines?
                I dont know what this means but "ASS HATS" is funny
                • #38
                  I'd like to know as well wiether anyone has tried different timing setups with the 96-97 DOHC
                  1991 Grand Prix STE
                  3.4 DOHC
                  1 of 792 Produced
                  Extensive Mods Done
                  1991 Lumina Z34
                  3.4 DOHC
                  Getrag 284 5spd
                  1 of 30
                  • #39
                    Is there a way to adjust the timing on the 91-93 engine without removing the timing belt?
                    92 cutty auto with a 97 3.4
                    93 convert with 3.4
                    • #40
                      Hey guys,when you say 6/6 does that mean advance the Intake 6 degrees and retard the Exhaust 6 degrees.
                      Pete
                      • #41
                        Originally posted by ez112 View Post
                        I did the 6/6 EXACTLY on my 96 and it didn't work out right.
                        I was led to believe that the 96 and 97 engine already has 4 degrees retarded exhaust than on the 95 engine.
                        So I put my car at 6/2 Meaning 3/1 on cam degree (marks on the tool) and it worked out fine.
                        This is a pitcure of 6/6 in PLACE and it didn't work wonderfully. This is the front bank (obviously). Notice which way the cams go. Think of the movement of the crankshaft. Whatever goes WITH the crank is + and what goes backwards is -
                        I'm only speaking from experience. Now you do whatever you want to do. I wound up tearing my car apart like three times til I got it right. (don't know what happened that second time :P )
                        P.S. I notice the scoring on your tool. What I did to help move the cam is bonk it with a RUBBER mallet to help move a subborn cam.
                        How can I get this tool to time the cams? I am about to order the noisy lifters from here since this is, apparantly, pretty much the only place you can get lifters for our engine.
                        By the way, I am on w-body and have a '93 Oldsmobile Cutlass Supreme Convertable with the 3.4L DOHC. All original with 66K miles at this time.
                        I am changing all the gaskets out from the head gaskets up and the lifters weren't pushing oil through the pumps anymore, so I decided to get new lifters as well.
