the project engine.. a 95 GTP ..
sawsall and die grinder with cutoff wheel made pretty quick work of the cast intake manifold
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0895.jpg)
here you can see the two biggest restrictions..
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0898.jpg)
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0900.jpg)
so the plan next was to weld a 3" tube to the ends of the runners after doing some porting to them to improve flow and use the bolt on throttle body from a 96
![](http://img.photobucket.com/albums/v435/kohburn/intake.jpg)
![](http://img.photobucket.com/albums/v435/kohburn/intake-take2a.jpg)
after cutting all the pieces and brazing them in place I took the intake to Coffee Hill welding.. they did an awesome job welding up all up for about 50$
I then ground down the welds and used some epoxy to fill in any dips
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0945.jpg)
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0946.jpg)
if you can fit your hand through a 3" hole theny ou can fist this intake to the back
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0951.jpg)
after sanding with 80 grit on a mouse palm sander.. adding 3 coats of primer and one of top coat..
![](http://img.photobucket.com/albums/v435/kohburn/Cam_0959.jpg)
now back to tuning
now back to tuning
