I might soon be starting an engine swap in my Fiero and I can get my hands on both the early and late model engines and the wiring harnesses and computers for each. The 91 would run me about $200 if I pulled it and the 96-97 $450 pulled (I forgot to ask if I could pull the engine myself for cheaper; if so, that's an option). I know the 96-97 is more of a pain to install. I can probably get my hands on the early engine's cams pretty cheaply if I go with the 96-97.
Which would you choose? Are the better heads and intake worth the effort? Would they be worth it after installing the lumpier early cams?
Leave as much extra input below as you'd like.
