2024 does not out perform all steel alloys in all specs. It may however excell in different areas over steel alloy. the only real benefit is it weight factor.
The steel that the cogs are made out of OEM have high tensile and are made to work hot. The hardness of the cogs out perform even forged vanadium steel.
I am not opposing this idea, I am just stressing other options.
Since the cog moves the cycles of limitations can be reached sooner than just starting the car every time, and since it is a two piece then there are stresses involved.
Like I said the timing system has a considerable amount of tension pulling on the belt, every time the cog moves the tension or weight is placed on a different part of the cog so in a sense the shear stays in the same place as the cog rotates, this weight pushes on the top part of the cog putting the force directly on the inner cog retainer outer side and shared with the inner side retainer bushing. After 500,000,000 rotations the 2024 aluminum will start to conical, in other words in one year it will fail faster if a daily driver.
This is not a belt driven cog like that of which you see on some motorcycles. GM made these cogs the way they did for a reason, and to save a few grams on rotating mass is worthless if it fails.
I will write it down that you actually know the physical properties of aluminum in most substrates. Sorry I can't read your mind I will try harder next time.
I don't know where you get your forged goods from but aluminum and steel alloy are about the same. Actually 2024 cost about the same has moderate grade stainless and some high grade steels.
Cogs are getting pushed, pulled, and torqued is that uniform....
