This is meant in no way to discourage you from getting CF clutch for your 284, but maybe it will open up a couple options. This is in comparison to a factory clutch I just picked up.
The pressure plate appears to be the same, just painted oragne. Eyeballing it I can tell no difference aside from the CF has what looks like a balancing weight on it. CF won't tell me the clamping load of the pressure plate or even if they modified it in some way, their loss.
The disc bears a striking resemblence to stock. All that it appears that they did was drill the outer disc rivits off (the ones that hold the friction material sides together) and replace the flywheel side with an 8 puc version. Same center section down to the little "DK" symbol. I have heard that the stock clutch is organic, and guess what, the pucs are made out of the same material down to the copper looking fibers in it.
