Valve comparison 1st design vs 2nd design cyl. heads
  • Valve comparison 1st design vs 2nd design cyl. heads
    After disassembling my 2 spare set of heads. I noticed a differance in exhaust valve shape. May be some potential gain's.
    Here's the differance in the valve head. One is dimpled the other isn't.
    Intake and exhaust both designs side by side.
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    RE: Valve comparison 1st design vs 2nd design cyl. heads
    Damn, i know I have posted pictures of them but I guess it was lost or misplaced. I will flow the difference later on when I am doing DOHC heads. The dish will lower compression obviously. I forget what the cc difference is with them in there now
      they should flow better.
