96-97 48 gram lifters????
  • 96-97 48 gram lifters????
    Anyone found lighter lifters for the 96-97 motors?
    UPDATE Found 53 gram 33mm lifters!
    Factory lifters weight: 62 grams
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    RE: 96-97 48 gram lifters????
    96 motors use the same lifters as 91-95
      ok my bad then 97 motors. the smaller lifter design.
        Anyone have pics of the 97 cams and cam carriers?
          I found another 33mm lifter but I need a stocker to compare with. I doubt its lighter though.
            I found some aftermarket ones. I ordered 3. I'll compare the weights Friday.
            I can take some tonight.
              That'd be great, thanks.
                Piiiiicsss?
                  series8217
                    Awesome. Thank you very much!
                      They did nothing to fix the horrible oil drainback. Interesting. All the same tiny passages and casting flaws I had to fix when I built my 93.
                      Anyone have pics of the oil distribution cover for the 97? I wonder if the passages are smaller to restrict flow to the heads.
                        Did you weigth the lifters? That will give a ball park#
                        Thanks
                        DreX
                          Factory 97 33mm lifters weight: 62 grams dry
                          Aftermarket 97 33mm lifter weights:53 grams dry
