dang. how did you get those numbers.
The dyno numbers are in...
Originally posted by OldSkoolGPHmmm, that's almost everything I started out with verbatim. Great minds must think alike! Can I ask what you using for injectors and fuel pump?sigpic
Z34 red, auto, written of by a red light runner.
Z34 white, 5 speed, stored in Canada
Mercedes-Benz C20K, Dubai
Mercedes-Benz CLK500 AMG, Dubai
Originally posted by robby1870I usually dont post in the DOHC section but, nice numbers man, keep up the good work!
Originally posted by Z34_nutvery impressive. I must ask how-ever. How much did this project cost?
Originally posted by jeremyvery impressive numbers how did you get a rebuilt 284?sigpic
All I have to say is you hear a car on the dyno and you can feel a good number. After we were on the street and the shift linkage was fixed I knew there was many smiles per mile comin out of this one. I will never forget the complete burnout across Troys parking lot tho smoke rollin off both tires and then shuttin it down for the street. It was a long project and there is more work to do but so far I am happy with the outcome.
very very interesting and good results you got! Awsome power for stock cams and intakes! I'd like to know what they would charge to have the heads worked over like that!3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
This opens up the whole which design cylinder head and intake is better.
Dr. Lightspeed your thoughts on this subject?
Custom JE pistons.....what was custom about them?1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Originally posted by your_I.D.Custom JE pistons.....what was custom about them?sigpic
Any special specs? Or just standard specs .030 over?1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
So I got the car off the dyno in Red Deer and brought it home to Edmonton now - runs like a top! There is so much raw power it's hard to believe! On the highway I never have to take it out of 5th, up and over the hills like they aren't even there.
The clutch has taken some time to get use to, it's VERY grabby and if you aren't aggresive enough with the gas it shutters the whole car quite a bit leaving a light. Only problem I seem to have is the exhaust system knocking on the body now, the bushings in the dog bone are torn out (they were fine before the swap!) and there is excessive engine movement now. I have a FFP dog bone but have misplaced it.
I was able to get it out last night and open it up a few times, lot's of traction problems out of the hole and quite a bit of break loose going into 2nd, mind you I still have the 225's on it. It sure hauls ass though - no comparison to the last motor that put down 197 WHP. I have to get the car in for an alignment then I can slap on my 255 45 17 Falkens - those should plant it quite a bit better. I'm not much of one to race on the street so I won't have any stories for you until I go to the track in Calgary on August 20th (hopefully) and Edmonton on September 17th, Lightspeed is a sponsor of the (Edmonton) event so I will be racing for them.
After that I will add the MSD, cold air intake box, retard the exhaust cams and add a few other electronic goodies. I'll be sure to dyno the car between EVERY addition so we can all see the actual HP gains from these mods, as well as 1/4 mile times.
I should have the rest of the pic's up this weekend, thanks for your patience guys!sigpic
If you have time try +6 intake and -6 exhaust for cam timing. That combo seems to work very well on the auto trans cars. Im currently running +8 intake and -8 exhaust. Has a slight intermintent lope at an idle when cold. Woke my 3.4L DOHC up BIG time.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
I told Ben that I would try out a few combinations as long as time permits. So far it will be the 13* for sure, and Ben wanted me to try out the 6* & 6*, so I will give it a shot. Such a pain in the ass to adjust the cams so I really want to share the info with you guys so you can determine if it's worth the time or not. I'm not touching anything though until I get some 1/4 mile times, then we can compare dyno numbers and track times between one cam time and another.
If there is anything else you guys would like to see tried out, let me know. I'll see what I can and can't do for you, the more research the better!sigpic
Ill be at the track today with the 6/6 timing. Ill probably try 13 degree timing out in a couple weeks time at the track, depending on if I ever learn how to launch this thing (225s as well, sucks off the line).
Id post more, and PM lightspeed now that I see they are on here, but i gotta get out to the hotel and see if josh is there (60v6 meet right now). Look forward to the testing of each part, this is excellent news for all of usBen
