ok i just got pretty much all of the parts for the swap but have some questions.
1. the pip that goes from the water outlet from the water pump infront of the engine is that nessessary. if you seal off the water outlet and seal the intake manifold what is the purpose. it cant be fore heat because the heater core attaches to the throttle body nipple and gets water from the upper radiator hose
2. do you really have to cut the tps sensor wire is there any way to get it to fit.
3.for the cables why cant you just switch out the hole assembely that theplate is attached to. then you will have the factory cable holders
i have a 94 z34 and dont have a map so is there any way to block off the hole on the intake tube
