Update to cam timing under DOHC performance site info
RE: Update to cam timing under DOHC performance site info
I read your write up and i will totally reference it when it comes time but i have a question.
I couldnt tell if you were saying if the engine now was better down low or better up high or both?1984 Indy Fiero 3.4L
13.7 sec @ 98 mph
*ALL THROTTLE AND NO BOTTLE*
The top end was better than stock but it wasn't as nice as the 13 exhaust retard. If I have to guess, id say it shifted the powerband down about 400 RPM vs 13 degree exh retard. The bottom end is much better than the 13 degree timing, and was better than stock as well. I personally think GM should have made the 6/6 timing stock cause it works so well with the automatic.Ben
+8 int -8 exhaust works awsome also with very slight intermintent lope.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
I am still confused.....
On the writeup, it looks like you set the timing with the crank set forward 13*; so was that with TDC #1 with the cams flat?
I thought the crank should look like stock pic, TDC #1, with adjustments made on the cam flats?
Am I stupid?95 MC Z34 Black
Originally posted by sappyse107I was thinking of trying that. Is this on a 97 or 91-95? 96 im uncertain of its stock cam timing though I side on the 91-96 idea.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
