Post your cam timing settings and results.
  • Post your cam timing settings and results.
    People keep asking about cam timing results. Low end improvement or not, idle quality, top end improvement ............................
    So I thought it would be good to have all the results in one thread.
    97 Automatic, completely stock other then a intake arm polish and port matched and ventilated airbox
    Started at stock cam timing settings.
    set to -8 exhaust cams
    +8 intake cams (+4 is already advanced from factory. So I actualy advanced it +4 add +4 from factory in cam already = +8
    Results: very intermintent slight lope at idle. Mostly when cold.
    Big improvement on midrange and noticeable improvement on lowend
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    would be able to get some dyno runs to see how much it actually increased?
    04 Escalade 6.0L
    08 Z06
    96 Blazer SFA
      I dont have one from before i set them. Tough to get a good comparision. but trust me it help. My little bro agreed after he drove it.
      I'll try to get dyno run next week.
