One of these days, I will actually have my engine back together. No, really...
I ordered the Sealed Power ringset for the later year pistons I was talking about earlier, and was dismayed to find out that they're ordinary iron rings (top ring is moly faced). The Perfect Circle set I ordered for my 91' spec pistons had steel rings with a moly topring. I want steel rings, damn it! At least give me ductile iron... For those unfamiliar, the 91-95 engines have a 1.5mm thick topring and second ring, and a 4.0mm oil control ring. The 96-97 pistons have a lower drag 1.2mm topring, a 1.5mm second ring, and a 3.0mm oil control ring.
I searched around, and it turns out that for the 96-97 application (my motor is 91, but I have 96+ pistons now), neither Dana or Federal-Mogul make a steel ringset for the later application! WTF? You'd think that with the improvements, that a tougher ring material would be a no-brainer. I don't exactly plan on battering my pistons and rings to death, but the extra strength of steel rings sounds like a good idea to me.
Question is, aside from Sealed Power or Perfect Circle, is there any other options for piston rings when it comes to the 96-97 spec pistons? Total Seal only appears to make a gapless second ring, but no topring if I'm reading them right. This may be a longshot - but has anybody ever bought rings for a later year motor that don't suck?
