Lower intake porting
  • Lower intake porting
    Im gasket matching a 94 z34 plenum and lower intake, should I port and polish the
    whole lower intake???
    Any advice will be appreciated , thanks
    Chilicat
    RE: Lower intake porting
    go for it. The lower intake varies, I have seen decent ones and some that need a ton of work. The side walls could use a good clean up.
      Thanks!!
      What about the plenum ?, (extrude honing out of budget) read something about acid
      porting, worth it?
        Ben have you ever tried using flexable ball hones? To do upper intake plenum. Thinking of the 97 type with the long runners.
        1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
