Hey... I'm a Newbie Supreme now. Cool
While I was waiting for my heads at the machine shop, I figured I'd go ahead and try the re-ring I was talking bout in the "maintainence" section. Long story short - there's corrosion from water that ate a couple thousandths into the bore of cylinder number 4. It isn't coming out, even after semi-cautiously wailing on it with the deglaze hone, which probably isn't a good idea anyways. Looks like it's time to open the wallet and get a rebore/hone done. I think that means new pistons, too. Having never done this before, I have a couple questions on this as well if you guys would be kind enough to fill me in:
- Any boring will require new pistons, yes?
- As far as pistons go, what options do I have? I have a couple ideas (see below), but I'd like to know what's been done.
- What does it cost to have a bore/hone done, ballpark? Is there anything else that would be a really good idea to have done as well?
I found that stocker pistons don't cost much (25-50 apiece depending on source), and I have a few questions about some specs I've found:
Sealed Power, for a 91 Olds Cutlass Supreme:
H813CP: 3.6220 EARLY or REPLACES LATE USED w/E548K RING SET
COMP
2)1.50mm;OIL
1)4.00mm
COMP DIST;1.458";PIN DIA:.9054
DOMED HEAD:.040" HIGH - w/4 VALVE RELIEFS
Sealed Power, for a 96 Olds Cutlass Supreme:
H684CP 3.6220 LATE or REPLACES EARLY USED w/E928K RING SET
COMP
1)1.20mm(1)1.50mm;OIL
1)3.00mm
COMP DIST:1.464";PIN DIA:.9054"
DOMED HEAD .040" HIGH w/4 VALVE RELIEFS
I have a 91' motor from an automatic. What caught my eye is that the "early" piston has a '.040 dome'. Looking at the piston sitting in front of me, it looks dead flat except for 4 valve reliefs. Is Sealed Power # H813CP a Manual spec piston? Furthermore, the "Late" style piston has a compression height that is .006" higher than the early style piston, and also has a .040" dome. It says "replaces early" in there, if I change to the 1.20mm late style rings.
Big question: Can I slap in a set of oversize H684CP domed pistons for the 96' year engine into my 91' motor for a little more performance? Will I end up having to use 92 octane or even higher with a light cut taken from the heads, the extra compression height, and the dome? Will this work without nailing valves? Does the motor become interference if I do it? If I can't use later style pistons, are the H813CP early style pistons with a dome higher compression than stock automatic spec pistons? I ask these questions because I'm sure somebody has looked up replacement pistons and knows from experience whether this will work or not. I figure if I'm going to rebore/hone and get new pistons, that I might as well get a little more punch out of it. This is a performance motor, after all!
Secondary question: Not to sound like a broken record, or a n00b whiner about gas prices and stuff... but does anybody have a general idea at what compression ratio one would need 89 and then 92 octane gas? I don't have the faintest clue what these motors like to drink under various compression ratios and such.
You guys know your shit. Thanks again for the help.
COMP
COMP
