Hows it going? This is my first post here at 60v6.
Anyways, I have a 91' 3.4 TDC apart for an R&R on the heads, and I was wondering what options (if any) I have for decking them to raise my CR some? It's an auto spec motor going into (well, coming back out of) a 87' Fiero GT on a 5 speed M282, so I was thinking 9.5:1 CR (like manual spec motors), or maybe higher depending on what I can get away with. Just a little boost, since I'm getting the heads milled anyways. I'll be up front in saying that this is the first time I've opened a motor with the intention of putting it back together, so I could use a little help here.
Machinist tells me he'll look some stuff up, but I'm basically going to have to know either how many thousandths to mill off, or perhaps how many CC's the combustion chambers need to be. He's gonna CC them when he gets a minute. I do need to learn anyways.
So does anyone have any information on any of the following:
- Has this even been done before? Surely somebody has
- Does anybody know what the gains are likely to be?
- How high can you raise CR safely (extreme case).
- How much can you mill off the heads before the motor becomes interference? How much can you go even after that? (I don't intend to find out, but it'd be interesting to know)
- Recommendations on what CR I should shoot for to get a performance boost without going to Premium gas (California gas prices SUCK)
- Any other tech specs or info I'm going to need to figure this stuff out?
Thanks in advance, you guys.
