Modifying the '91-'95 Upper Intake Manifold
  • #16
    Originally posted by Lyle's GTP
    Has anybody ever thought of making something from plastic. I had talked to a plastics fabricator here in Edmonton once. I had some ideas for a custom air box. He said If I could build a mould out of MDF he could shrink ABS plastic over it. He also said that doing some plastic weldiing was another option aswell. He was really cool because he said he could made provisions for fastners and the whole nine.
    So, since so many cars are going with plastic intakes any way why not do that. Shit, you could easily build a two stage manifold out of MDF and wood dowel and fiberglass. Make it two pleices then have it plastic-welded together. Not to mention, that the surfaces would be perectly smooth, no porting nessesary. He was telling me for the airbox design I had in mind it would be no more than 200 bucks.
    I'm sure Ben that you know exactly the volume and and length of runners you want. I say start playing.
    If, I wasn't planning to do a blower that's what I would do.
    Lyle
    I'm interested in this. It is tempting to almost start taking measurements for what I would consider "optimum" volume and length's of the runners...
    1992 Miata B Package
    1995 Regal 3100
    1996 Firebird LT1 T56
    • #17
      I have an intake idea to throw out there.
      You ever seen or familiar with Dog Thorley Tri Y headers. Take that concept but reverse it. kinda. If you take two opposing cylinder intake strokes. and y them together 6=8 inches before LIM (intake runner volume equal to volume of air drawn during one intake stroke of piston) Then collect the remaining 3 tubes into a collector for the throttle body. The intake charge velocity would stay up avoiding reversion. It would act as one long intake runner to each cylinder. Since they would alternate air intake.
      I'm I making any sense to anyone?
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
