3.4 DOHC turbo
  • 3.4 DOHC turbo
    Here's a link to my post on mymonte.com. I'll repost the text here, but the pics took way too long to get uploaded over there and it's not just easily transferrable html code. Enjoy!
    Get the premium .com domain you deserve. Seamless and professional transactions. Payment plans available.
    I have a lot of old threads on this and a bunch of scattered information, but no common thread with everything. IMO, this is almost perfect for a 3.4 DOHC turbo setup and is what I wanted from the beginning.
    Setup info
    T04E 60 trim turbo with tangential T4 exhaust housing
    Turbonetics Deltagate 5-7 psi wastegate
    1st generation DSM BOV
    ADFX racing 1G DSM intercooler 7.5"x3"x24", 2.5" in/out http://www.adfxracing.com/default.as...&category_id=2 with custom hood support welded from 1"x1"x1/4" angled steel
    Vortech 12:1 FMU
    Split Second FTC1 (ability to retard ignition timing and alter MAF signal based on boost/rpm) http://www.splitsecond.com
    Manual fan switches mounted in side of center console
    Redline Water Wetter
    2.5" mandrel bent/press bent downpipe
    3" with 12" Borla muffler to dual 2.5" with dual Magnaflow XL mufflers exhaust (3" highflow cat or 3" test pipe)
    Autometer Carbon Fiber a/f ratio and boost gauges in a custom molded Honda Accord 2 gauge pod
    MAF mounted before throttle body
    BOV mounted before MAF
    short radius rubber 3" 90 on end of turbo to 3" silicone 90 to filter in the fenderwell
    new windshield washer pump and reservoir
    Rebuilt transmission with all HD parts, transgo shift kit, and quad4 torque converter
    Boost comes quickly. From a stop it's at full boost in less than a second. The new intake is the ultimate setup IMO. I tried running 3" carb piping to a filter in the fender and also a 4"diax2" thixk 1bbl or 2 bbl carb filter directly on the turbo and neither flows nearly as well as this setup. Spool time increased significantly with the 4"x2" filter and ultimate power also suffered dramatically. The exhaust changed from a 2.5" to dual 2.25" press bent to a 3" to dual 2.5" mandrel bent setup. The new setup is far superior to the old one. The FTC1 is retarding timing by 1 degree at 7 psi and 1 degree per pound of boost above that.
    If you have any questions, feel free to ask. I have some old videos and quite a few high res pics if anybody is interested.
    Exhaust
    Split Second FTC1 install
    Tim
    325 whp 350 lb-ft
    RE: 3.4 DOHC turbo
    All I can say is DAMN I wish I had your setup
    95 MC Z34 Black
      I noticed you said you were running a MAF. i've read you really can't crank up the boost that high if you're only monitoring mass air is there any advantage to not using a MAP? I'm terribly interested in tubo-ing my car someday. and i'm trying to learn all I can
        there are lots of tricks around running a MAF with lots of boost. I'm using a MAF not a MAP because that's what my car came with. My stock computer will not understand a MAP sensor and with a MAF it doesn't care that it's boosted. I do have a piggyback with a MAP that allows me to alter the MAF signal. I'm guessing that you have an earlier 3.4 with a MAP. There is the possibility of retuning the ECU for a larger MAP sensor or tricking it into not seeing any boost and adding fuel with an FMU.
        Tim
        325 whp 350 lb-ft
          Are you using stock internals?
            did you ever contact Ryan Gick at www.gmtuners.com? He burned a chip for me for the 94-95 PCM. Im still beta testing with the fiero but im sure that he could at least get you one for the auto because it is much less complicated. Looks good man, how much you got into the turbo setup?
            3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
            1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
              That thing sounds awesome. Per chance do you know the a/r of your exhaust housing? Also, has this monster seen a track or dyno yet? I'd be interested in seeing how well it works.
                I asked the same thing at the W-body board and I believe Tim stated that it was a .68 A/R housing.
                Matt F.
                TGP 1/4 mile times
                http://photobucket.com/albums/y33/mfewtrail/
                1990 TGP Coupe VIN Database
                  Stock internals. It should be a 0.68 a/r turbine housing. No times or anything yet, but hopefully soon. I will be contacting Ryan Gick about that chip soon. It sounds like he can probably take care of everything I would like done!
                  I've probably got about $4k in it now since the piggyback, new exhaust, and new intercooler piping.
                  Tim
                  325 whp 350 lb-ft
                    I am using a similar turbo on my 96 3.4DOHC. Only mine has the .80A/R turbine housing and a modified GT35 turbine wheel. The comp is a .60A/R T04E with a 62-1 wheel.
                    I will also be using MAF, but I'm up-sizing to an LS1 MAF and using GMPCM software to tune it.
                    Jeff Ianitello
                    Engineered Performance
                    Atlanta, GA.
                      Tried the link to the mymonte site, and they didn't work. Maybe they're working on the site, so I'll try later.
                      92 Lumina Z34
                      Found coolant in the oil and metal in the filter.
                      Also found a home in the engine compartment for a turbo and intercooler
                      <a href=http://www.cardomain.com/memberpage/813554>Some pics at CarDomain</a>
                        same prob for me.
                        1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
                        1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
                          Dyno results are in. 263 wheel horsepower at 7 psi. I've posted the best pic I can (it's small). If anybody wants a larger, higher quality one- e-mail me.
                          Tim
                          325 whp 350 lb-ft
                            That's greta Tim! That's MORE than 50% more power on LESS than 50% more atmopheric pressure. In other words, theoretically you'd make 249whp on 7psi from the stock 166. I have seen this on DOHC engines. they are very inefficient on natural aspiration! it really takes a turbo to make a DOHC head shine! On 10-12psi, you'll be way over 300whp.
                            I am shooting for 350-375whp on 15psi in mine... if I ever get it finished.
                            Jeff Ianitello
                            Atlanta, GA.
                              Hey Tim, so your letting the stock computer (no mods to chip) run the turbo?
                              Also, hows the MPG? Drop a lot/little? Or barely noticeable?
                              Thanks,
                              Jay
                              New member of 200,000 mile club as of May 16, 2005
