Originally posted by Q
Heres a cam idea for the DOHC
1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Heres a link that will explain cam timing in degrees.http://www.iskycams.com/pdfcatalog/2004-05/page205.pdf1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Originally posted by Wolfwhat about getting 2 pairs of quad 4 HO cams,then cutting them down to the 3.4's cams length?
I'm sure thats completly crazy tho.. hehe:P
the lobes are set at 90 degree intervals, the 3.4 dohc's are set at 120 degree intervals. Also the cylender spacing on the 3.4 DOHC are about 3/4" more then on the Quad 4 so the lobes are also 3/4" further apart. ALSO, the Quad 4 cam journals are just over an inch wide. while the 3.4 DOHC's are approximatly 2" wide. So you would have to add alot of metal.
You MAY have won todays dumbest, most least thaught out: "you have got to be fucking kidding me!" post of the day. Thanks, I needed a good laugh, I know you were joking. (or at least I hope)
Since there is about a zero percent chance of that plan working, it gives me one stupid, but not all that impossible idea... Take the Quad 4 cams on a lathe, cut the cam before each lobe, then machine a 1" hole through the center of the lobe (easy work for a lathe) then cut the lobe off, and carefully TIG weld them all onto a piece of 1" steel bar stock. and put roller bearings between each lobe pair to support the cam in the housing... not impossible, just highly impractical. like putting the DOHC's heads on the aluminum block.
I think Im going to make a stupid post in the quad 4 forum for shits and giggles, look for it when you get a chance!
here, have a laugh it was actually quite difficult to misspell so many words and forget almost all the punctuation. I might have tried too hard though. Its obviously a joke I hope.
Originally posted by FierobsessedOriginally posted by Wolfwhat about getting 2 pairs of quad 4 HO cams,then cutting them down to the 3.4's cams length?
I'm sure thats completly crazy tho.. hehe:Pheres to one of my stupid q's lightening someones mood
well I wasn't joking,but I didn't expect it to work(I figured the bearings would be diferent... I didn't even think of spaceing)
1995 camaro 3.4 5-speed
I do have a solution to the cam timing problem with two exhaust cams. If the flat that is on the cam is well out of the way, you could possibly TIG weld on a piece of steel to use as a new flat, but placment and height of that piece you weld on is crucial for a proper timing of the "0" degree point of the cams. The stock intake cams are probably your best bet for finding that zero point. I still would like to know if the intake and exhaust cams are any different, and if so how much.
According to spec. listed on main page:
Lobe Lift (Intake)
0.370 @ 108° Crank ATDC
Lobe Lift (Exhaust)
0.370 @ 115° Crank BTDC1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Wont work. exhaust cam is missing a key feature.........
No casted lug for cam sensor to pickup off of.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
ok then it will physicaly work. Just need to figure out timing issue.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
You cant use the timing flats to set intake(really an exhaust cam) you'll end up with 4 valves opening on the exhaust stroke.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
maybe im thinking of something esle than you are...
Ill time the new intake cam to where i want it. the 4 valves arent going to open at the same time if the cam is phased with the original position of the int1984 Indy Fiero 3.4L
13.7 sec @ 98 mph
*ALL THROTTLE AND NO BOTTLE*
Right, but there will be no way to use the timing flat to set. It will have to be done by degreeing the intake cam. Or guessing.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
