Heres a cam idea for the DOHC
  • Heres a cam idea for the DOHC
    The exhaust runs about 10 degrees more duration and a little more lift in a DOHC.
    Why not run 4 exhaust cams instead of 2 of each? If it will fit and there isnt any other issues, then its an easy increase isnt it?
    I tried a search first.
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
    RE: Heres a cam idea for the DOHC
    In other words, your suggesting we replace the intake cams with exhaust cams, correct? (i found your wording slight confusing :P)
    Sounds like a good idea to me, then again i know nothing about this engine.
    2001 Mustang GT
    1991 5spd Lumina Z34 - Dead
    1947 4spd International - Dead... Reincarnation pending.. getting close now .
      Yeah sorry thats what i was trying to say. Replace the intake cams with the exhaust cams.
      13.7 sec @ 98 mph
        I'm sure nobody knows what to make of this post......???
          Aside from not wanting to degree the cam to make up for the offset....where do you get that there is 10 degrees more duration?
            Intake and exhuast cams have different spacing between the lobes, won't work as far as I can see.
            95 MC Z34 Black
              This would be such a clever solution if it worked! I'll take a look at the cams next time I have the engine right-side up to see if it's at all feasible.
              Hey napatiger, check your PMs.
              -Steven
                Well after looking at my heads i think i can make it work. Anyone have a spare set of Exhaust side cams they want to donate? Ill dyno before and after.
                13.7 sec @ 98 mph
                  Lobes look pretty darn close to me. Nothing the lifters would care about. It would be a cool idea.
                  86 fiero GT + 4 speed munci + 94 GTP TDC = Fun!
                    i have a whole cam carrier complete with intake and exhaust cams still intact. How does $60 shipped sound considering most of the $ will be shipping? If you feel price is high, name it and they are yours including shipping of course. Let me know
                    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
                    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
                    - 160* T/stat - Dual 40 Series Flowmasters
                    - Hi-Flo Cat
                    15.2@95mph - GTECH P/B
                    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
                      PM sent
                      13.7 sec @ 98 mph
                        How do you plan on timing it?
                        Q
                          May the force be with you.......
                            Any new info on this. Maybe someone can put the specs in Desktop dyno and see what we might see with this.
                              Now THAT ought to be interesting... Keep us updated.
