Hi-Performance Flywheel bolts.
  • Hi-Performance Flywheel bolts.
    Hi guys, well I do some research and found Hi-Performance Flywheel bolts for the 60* V6. ARP makes them, not specifically for the engine tho.
    The Bolt specs are M10x1.00 Pitch. So, after found that I went to ARP and the Ford Pinto Flywheel bolts do the trick. Heheh, who will imagine using a Pinto part.
    The part# is 151-2801, they hold 180,000 psi and are far superior the the OEM counterpart. The most awesome thing is that the set of six bolts cost only $10!!! The GM dealer will sell you the Z34 BOLT(each) for +$5!!!!!! So we are talking +$30 for 6 inferior bolts. No brainer, I order 2 sets.
    For my application the fit just fine. I had to use a pressure washer because my flywheel. Maybe with stock flywheel you will have to take off a bit to prevent to bolt to reach the buttom of the crank thread.
    Well, keep the good work and share the knowledge.
    Dre
