No idea, but I highly doubt it was a full second faster (if I had to guess Ide assume he ran 15.4-15.5), but I think it does shows the 3.73 and stall is def a good step closer to 14s
Traction would help as well if you had some nerve to do a bigtime neutral drop...lol
I know a stock LT1 6-speed was hitting flat 12s with ONLY suspension/gearing. FUll drag setup, no brakes, skinny front tires, wheelie bar, and bigass slicks out back. He said he was redlining 5th crossing the line.
Speaking of weight anyone know how much factory rims weigh
1991 Lumina Z34 - http://members.sounddomain.com/lcmbear77
1979 El camino (Faster of the two)
FFP Stuff (chip, D Bone, UD pulley)
Custom STB,WAI with K&N, Full Catback with Dual Magnaflows and Rative tips, 3k stall and 3.73 gearing coming soon
What mods are on your car, Aaron since you run in the 14s
Eh 13s actually...By comparrison to my other races at the track, and using the alt corrector, it turned out to be a 13.83. I beat a 6-speed 350Z by .15 seconds, and beat 3 different Z28s(1 LS1 auto, 1 LT1 auto, 1 LT1 6-speed). By some other comparasons there was a 5-speed SHO running mid 16s, a Lightning running low 14s, a GTP running 15.9s, and a Mustang GT that somehow pulled off a 14.8, and it was stock...
As for the mods, here they are up to date(1/4mi of a 15.22 here in Colorado)
True Cold Air Intake(fenderwell), 10:1 compression(up from 9.5), .030 over bore, equal length headers, Magnecor 8.5mm wires, full 2.5" mandrel bent exhaust, FFP UD pulley/dogbone, chip form Ben, custom front STB, and I think that is all...
The 14.78 was alt corrected a 14.56, and that was with everything but the new motor(so I had 9.5:1 and no bore, and an old motor), and without the headers.
Dang I would have loved to see the look of that guy face with the 350Z
alt corrector ?
altitude. He hasnt ran a 13 yet cause he runs at 5000+ feet. Of course if he did, his fueling may be inadequate to actually hit the imaginary 13 to begin with, or any other number of things could happen. It should be near the 13s but its not official yet.
ohhhh aaron lives in colarado. I live where the altitiude is 12 feet above sea level
yeah the altitude is only like 12 feet where i live to and all the salt in the air from the ocean, and the roads in the winter makes a natural weight reduction kit. lol
