Is there any way I can port out the passages in the block, heads, and lower intake to help flow more coolant? It should be good for about 15hp at the wheels...
Sorry guys, had to post another "porting" thread because of all the recent ones!
Have you noticed how small the holes are or the coolant to flow through in the headgaskets? I was going to match them to the actual passages but was told not to as they were designed that way for the coolant to not flow as well, which would cause hotspots and overheating.
