I was just laying in bed, with all kinds of visions running through my head. I couldn't sleep, this idea kept me awake: I was wondering if anyone had tried to take a pipe, weld a cap on one end, a flange on the other, bolt on a TB from a later model F-body, and bolt it to a stock LIM on a LQ1. I think it would probably work, and not lose a ton on the low end, and flow a shitload more air. What do you think?
3.4 custom intake
Well, my original plan was to go with two intake pipes, one for the front bank and one for the rear. That way,I could have had one blade for each bank. Dont ask me why I changed it to just the pipem however, it was late and I was tired.1993 Lumina Z34 - Broke Yet Again
What the flip Uncle Rico!?!
Originally posted by AaronNot onyl that but when you are at part throttle on the LT1, only 1 plate opens. This helps your low end. Then at like 60% throttle the other plate starts opening. Kinda like mechanical secondaries on a carb-without the fuel of course.
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
Originally posted by AaronI was wrong
I did some research, and both plates do open at the same time. The reason was to direct the air from one plate into one side of the motor more directly. I was told a while back that they were staged, but that dude was wrong as well.
