Just to have some fun, how would you go about bullet proofing a LQ1 and at what power level would it fail? Seen a couple turbo LQ1's in Fiero's that are in the 400-450hp range but it is a very small sample size to get any information off of as far as reliability.
Rods/pistons: Probably as strong as you can afford to buy. Stock rod length or change it? Larger wrist pin?
Crank: GM steel 3500/3900 crank, leaving the stock 2.25" crank pin diameter. Anybody in the turbo 3900 crowd manage to break one of these yet?
Block: How much abuse can he stock 2 bolt main block take? Drill for 4 bolt? Girdle? Sleeve it for more displacement?
Heads: How much power before they lift off the block or crack?
Intake: 91-95 or 96-97? Probably not necessarily the best flowing engine anymore but are there any (uncorrectable) limitations that would be hit with not being able to flow enough?
