Feul pressure
  • Feul pressure
    What should the fuel pressure be on a 96 cevy lumina with the 3.4L DOHC? Thanks
    target of 43.5PSI with either the pump running and engine off or engine running with no vacuum to the regulator.
      Thank you , the specs I found said 38 -52 lbs. I thought that sounded a little off.
