Going for 300whp NA
  • #31
    Thank u robet
    Sent from my MB886 using Tapatalk
    • #32
      Isn't the 3500 crank an interference fit in the 3400 block without major clearancing? If so it would be the same way in the DOHC block.
      I seem to remember reading it wouldn't bolt right in a 3400 block, but I could be wrong.
      • #33
        That and doesnt the 3500 crank also have a timing gear in the middle of the crank that would have to be machined off
        • #34
          It could be pounded off. It's pressed onto the crank, not machined into it.
          • #35
            Originally posted by 02dohc View Post
            Thank u robet
            didn't know you already had the pistons, just throwing ideas out there to try and help.
            • #36
              who knows, the 3.4 DOHC block is probably closer to a gen 2 in the interference areas.. it could be worse or better than a 3400... most likely way worse.
              If there is enough meat to make space... then use a 3.6 crank.
              • #37
                i'm sure it's stronger than the stocker, but any other reason? 3.6 has a stroke of 3.37 compared to the 3.4's 3.31... displacement gained is pretty minimal, though it brings the "3.4" up from 3349cc to 3412cc.
                • #38
                  just the small stroke gain, I always wanted to put the 3.6 rotating assembly in my 3500. That would have been fun.
                  • #39
                    it'll bolt in???
                    • #40
                      Well the rods and pistons are a really close match
                      '86 Fiero, 3500, 4-speed
                      • #41
                        I think it was really close in a 3500, ended up at like 14:1 scr. The mains are extremely close, you can check the specs in the download section.
                        • #42
                          Going for 300whp NA
                          I'd be really surprised if the crank could actually fit. But it would be cool. They're built for more power. I do wonder about the pistons though; being cast, can they really be as strong as the 3500 pistons?
                          • #43
                            So hopefully I can get my taxes done today, and order hp tuners in a couple of weeks. The block is at the machine shop getting honed and line honed and overall ready to be rebuilt
                            • #44
                              food for thought, DHP powrtuner software is still available, all you need is a AVT 838 or AVT 841 cable, and you can flash a PCM. then if you get tiny tuner, you can change most anything you would need.
                              • #45
                                I can't find a dhp power tuner. I would love to have that instead of HP tuners. Can u tune everything including trans shift points with dhp
