So I have some updates for the thread as of now.
I have gotten the cylinder heads gasket matched and opened up on both exhaust and intake sides. I have had a three angle valve jobs done and also new knurled and oversized valve guides installed. They have been planed flat as well
This is before the gasket matching
This is after
And then I got the lower intake manifold matched the same,
I got a set of stock L67 injectors with wiring
I am about 2/3rds of the way done with my short runner intake and n* throttle body build
This is a pic of the plenum mocked up on the cut uim.
This is the mock up of the full intake without the throttle body adapter. Just tack welding it together so it can go to get tig welded.
This is after
