Ok lets see if I understrand this correctly.
So the ECU controls how much fuel the motor gets, and keeps it so the air/fuel is dead on. Now with the independent throttle bodies, my mtoor will eb able to get a lot more air. But the ECU can only ocmpensate for so much, becuz the injectors/fuel system can't keep up. Therefore if I put in bigger injectors and a new Pressure reg, boost the pressure a bit, assume the pump is good enough, then the ECu will eb able to add enough right?
So as long as I add the injectors and regulator, it shouldn't lean out? Or do I have to tell the computer, by tuning, that it can give more gas.
I thought I knew a lot about our MPFI system, but I guess I do not. I know the basics and how it works, but not how to modify it.
Thanks a lot for any help!
(btw:I ordered the 6 throttle bodies and 50mm air horns and the fuel rail to the tune of a lot of money, they will be in next week. My flanegs are being cut as we speak and should be done around the same time, maybe a few days later. I have found tapered pipe, and will order that soon.)
PICS WILL BE UP AS SOON AS I GET THE BODIES
