I found this from an old post from hayesperformance. Last week I took the RedNblack through our "dead Man's curve", I-71 N where it merges with I-90 E in cleveland.
New tires all the way around, a dremel on the rear strut to spindle holes to correct the camber, nylon blocks for the mono-leaf tips, 1 ball joint, 1 tie-rod, left, a headlight switch, both rear hub bearing, calipers, rotors, and ceramic pads. I think I'm catching up on her!
We approached the curve at around 110, dropped a gear, and dove into it, she hunkered down and bit in beautifully! speed dropped to around 85 and we started a controlled slide under WOT. I straightened the wheel a bit, still accelerating through the curve around 95 now, and let all four tires scream as we slung to the outside of the curve when BANG! the ass fell out. Shit got REAL! REAL fast! Back side felt like it kicked harder outside, we slid out into the berm, that concrete wall got extremely close, when I got her back under control. Back left trailing arm failed. So now I'm going to rebuild the ass.
12498649 I can't find it, any ideas? Anyone make the other "control arms" for the backside too?
