Starting the brainstorming process to figure out the details of what I am going for (ie, how broke I will be when finished). Hopeing someone can help with the finer details for the ones I have long since forgoten and the ones beyond my understanding. Application is going to be a high boost turbo.
91-95 vs 96-97
-Are there flow rates for both types of heads
-Any block differences between the years, it is just front cover and heads up right?
-What is the combustion chamber volume for each?
Stroker with offset ground 3500 crank, 5.7" SBC rods, custom forged pistons
-Is there enough height in the stock piston design in order to use the stock SBC sized wristpin and also raise the height of the wristpin? (wristpin center would need raised 0.125" roughly right?) Does this put the wristpin into the oil ring?
-Is there enough block height so that the piston isn't pulled too far down at the bottom of the stroke?
-Any clearance issues with the block.
-Looking to use the dished 3.4 iron head pistons or similar design. This would lower the compression and also correct for the slight raise in compression from the stroke increase.
Block
-I am seeing youtube video's with around 420whp on the LQ1 now. Has anybody found the upper end for the bottom end strength?
-Is there enough meat on the block for custom 4 bolt mains?
-Anybody used the 3x00 main caps without using the cross bolting? The caps themselves look stronger.
91-95 vs 96-97
Block
