Maybe a dumb question but when you say advance intake 6 degrees and retard exhaust 6 degrees. Advancing would be before TDC and retarding would be after TDC w a degree wheel??? Well 12 degrees at the crank anyway. Reason I ask is I recently purchaced a 92 z34 w a broken intermediate shaft that ran good just made noise from the timing belt. I removed the engine and replaced the shaft and degree'd the cams and now it runs poorly at low rpms but good at 3k and up. Im not sure if I have other problems or I did it wrong?? I'm not to excited to have to tear it down to 0 everything to be sure. Any help would be appreciated
![Sad](https://www.60degreev6.com/vb5/core/images/smilies/icon_sad.gif)
