92 Lumina- have built eng. but I am not sure about the computer doing the fuel and ign. right plus the speed sensor needs unhooking or reseting. street strip- no DEQ. any ideas?
comp. work 3.4 DOHC
JE pistons,10.5 comp,1mm top,1.2 second, balanced,decked,line hone,mild porting .030 more lift W/a little more duration,trickflow valve spr. nearly doubled the press. don't know much about injectors so need info. the speed sensor only lets me go 125 mph,4200 the starts interupting or something else is. can't find headers but am going for dual ex with cutouts. engine still on the stand. just opening up trans
You need a chip to get rid of the speed limiter. your sensor is fine. Injectors, trailblazer would be plenty but the connectors have to be swapped and the tuning changed for sure. Those valve springs are probably too stiff but you are just giving up some belt life with that. Guessing you had a regrind done on the cams for that lift.Ben
where do I get a chip?I need to order injectors so need part #how can you tune the computer for timing and fuel delivery. I'm used to a Holly and a crank-trigger. this computer thing is new to me so any help apreciated.sending converter out for 2500 stall andwhat ever else needed. I know the guy who ownes A-1 Trans, local .
Ben's right, Your blind without data logging, a wideband 02 will also come in very handy if you have access to one, I have the Innovations one for that.1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
I am not up on the computer adjustments and don't have a laptop. the car is tore apart so I guess thats got to be running to do what I'm wanting. I think I'll put the stock size injectors in it for now. Just got to go thru the trans.and put it back in. I also have a 92 5 spd Lumina that is showroom cond.53000 on it. So this other one is just for hotrodding. So your saying I need someone locally that understand this data logging?
I'm not sure if you will get a response. This thread is 2 1/2 years old and I don't think Stanley has been around for a while.-60v6's 2nd Jon M.
