So im under the impression that DHP PwrTuner doesnt support the 97 LQ1... But i am able to open and edit the 97DOHC bin... Anyone use pwrtuner with the 97 LQ1?
PwrTuner and 1997 DOHC ?
Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)Tags: None
If you can open the bin then its supported. Files that are not supported simply will not open end of story.
well Ill be damned! i have allways been told the 1997's wont work but it does..... HMMMM rebuild 4T60-E or swap to 4T65-E HD?
SShane "RedZMonte"
Originally posted by RedZMonte View Postwell Ill be damned! i have allways been told the 1997's wont work but it does..... HMMMM rebuild 4T60-E or swap to 4T65-E HD?
S
I have been tuning my 96 bonne with the Powertuner (1997 PCM) for three years. I didn;t know the LQ1 was part of the package, but I guess it is. If you use the 4T65E, you will need to use a calibration that supports it, but you won't find one to run the 3400 DOHC with the 4T65E.Jeff Ianitello
Engineered Performance
Atlanta, GA.
Originally posted by pontiacjeff View Postor buy one of my 4T60/65 hybrid transmissions with EP-LSD.
But for now I have to stick to what I can afford. I have yet to really break it yet... other than wear out the teeth of the 2nd drum, and If the hybrid you makes swaps to the 65e style reverse shell then that may be the route I need to go; that is if I cause the same wear over the next year or so.
Originally posted by 3400-95-Modified View PostSome day... I will take you up on that...
But for now I have to stick to what I can afford. I have yet to really break it yet... other than wear out the teeth of the 2nd drum, and If the hybrid you makes swaps to the 65e style reverse shell then that may be the route I need to go; that is if I cause the same wear over the next year or so.Jeff Ianitello
Atlanta, GA.
Originally posted by SappySE107 View PostSome 97 3.4 DOHC used the 4T65-E. I use HPTuners for my 97 DOHC computer.Jeff Ianitello
Atlanta, GA.
Just check the bin, does it have pressure and shift time tables? My 1997 Venture one does, and I'm only assuming since it has those tables if I can figure out what pins would control the trans then I could add the 65e in my car.
And Jeff, I can only imagine what needs to be machined to fit.
But at the same time thats one thing that does worry me. I've worked on a circle track car for about 7 years now, and I've seen my fair share of mixing and matching transmission parts to get a better 2nd gear ratio, or to try a special 4 speed with different ratios as well, and 9 times out of 10 the mixing and matching results in broken parts. I'm not saying thats what happens with your setups, but the whole idea just brings that to my mind.
Hence why I will wait till I blow the shit out of what I have, or just burn it up before I start mixing and matching. Hell I already took the plunge and did the 3500 top end on a 3400... thats a step toward that right... LOL
Originally posted by 3400-95-Modified View PostJust check the bin, does it have pressure and shift time tables? My 1997 Venture one does, and I'm only assuming since it has those tables if I can figure out what pins would control the trans then I could add the 65e in my car.
Hence why I will wait till I blow the shit out of what I have, or just burn it up before I start mixing and matching. Hell I already took the plunge and did the 3500 top end on a 3400... thats a step toward that right... LOLJeff Ianitello
Atlanta, GA.
the 1997 Z34 Monte does have a 4T65-E and does have shift tables for the trans. im supprised it tunes the 97.. Good news for meShane "RedZMonte"
S
Overfilling 2qts and royal purple atf are my secret.
Yes dhp with do 96 and 97
hp only can do 97
No 96 you can not change line preshure
97 bin is double in size of the 96 bin. They changed every thing and it has every table that the 97 gtp has. Including performance shift mode that is disabled but can be enabled and set up. The 97 swap is an all around good thing.Last edited by Dave96z34; 06-03-2010, 01:01 AM.
Originally posted by pontiacjeff View PostYou still don't have enough power to hurt a good 4T60E. They are a very good transmission. Be sure to run an auxiliary cooler with a large capacity and overfill the transmission by one qt. Also, use Ford Type F/FA fluid.
Dave96z34 I have yet to do that performance shift, but I really want to turn that on so I can have some reasonable shift tables when driving around but at the push of a button I can bump them up more aggressive.
Its good to have also if you go to the track so you dont have to change 3 tables to change a shift point.
