MSD coil packs?
  • MSD coil packs?
    ok i was looking at my friends l67 and the coil pack setup seems the exact same would i be able to buy the same msd coils that he has and be able to hook them up to my ign mod?
    that's because the 3x00 and 3800 motors use the same type of ignition: wasted spark.
    the coils themself would fit perfectly, but wether they are any better than the stock coils is questionable.
      Yes, as Robert said they are the same and you can use them.
      Besides them being Red, will get any benefit? probably not.
      The stock coil packs are more than enough.
      As of April 2
      Engine: 2006 SV6 3500 LX9
      Trans: 2002 Getrag F23 5speed
      Injectors: #36 GTPs
      TB: 65mm TCE
      Maf: 1999 3400 Montana.
      Beverages: Ice Cold CANADIAN.
        i have to say its hard to say which is better, when i had them on my beretta i noticed a difference. but i think i'm the only one who has...
          I noticed a difference... when they jacked up my ICM and caused missfires all the time.
          stock all the way.
            One of the best thing GM ever made was the coil pack ignition. some are running crazy boost on the stock Ignition
            Mike 60degree addict.
              If your factory coils are excellent, then I'd spend the money elsewhere, I only noticed a small difference with the coils,
              on the other hand I really noticed the DIS-4 hooked up!
              But it will vary according to the number of mod's done on your engine/vehicle
              1991 Grand Prix STE
              3.4 DOHC
              1 of 792 Produced
              Extensive Mods Done
              1991 Lumina Z34
              3.4 DOHC
              Getrag 284 5spd
              1 of 30
