LY7 injectors.
  • LY7 injectors.
    I'm in the process of needing some new injectors. However I'm having difficulties finding information about the current injectors for the LY7. (Aura XR, G6 GXP, Malibu LTZ etc etc)
    I believe they are 28# injectors, with dual spray patterns.
    Does anyone have any more information on them, are they Peak & Hold or not? Low/High impedence? Are there any drop in replacements?
    If you guys have any information on this, I would be appreciative.
    1998 GTP --> T62 Turbo swap! - Done & gone
    1993 T72 MKIV Supra - Gone (another soup to follow)
    2008 Aura XR LY7 (Daily driver) - Current project.
    Bump.
      Looks like this hasn't caught on YET.
      On paper, it looks like the engine of the future (6 Cyl anyway).
      I posted a call for exterior measurements recently (see a couple posts below). Short of going to a boneyard and measuring the mounts, oil pan etc, I don't know if I'll be able to use it in my Stalker. , I haven't seen anything but a couple photos of the motor with all the Caddilac plastic hiding the cam covers.
      I's like to see how you've used YOUR motor (i.e. is your application a 7-esque or a full bodied car or ??)
      cheap r4 ds
        I found some info today after a lot of searching. They are apparently rated 23.6 lb @ 43.5 psi. Yes they are a dual pattern injector (all DOHC engines are) and GM only uses high impedence injectors that I've seen so I'm assuming these are the same.
        Jesse M.
        3x 1990 Turbo Grand Prix
        1987 Monte Carlo SS Aerocoupe
          Thanks man I appreciate it.
          I've done a couple of mods gonna see if I can get them thrown up on my website and I'll share them along with some dynos and data.
