so i tore the intakes out of the car, replaced the lower and swaped fuel injectors over... Everything looked good from there out.... (got the 1995 valve cover gaskets to work on the '96 valve cover (very simmilar)) set the upper intake on to check for problems, looks good.... went to attach the TB arm... F me! the fuel lines that attach to the fuel rail don't clear the downpipe... tried the old lines, looks good untill the tb arm gets put back on, no go....
So now ive got 2 options
* try to make custom fuel lines (hard lines) w/ the correct fittings for the quick connects
* modify what ive got and make a new intake/TB arm
it was feeling good untill i got almost done and hit a wall...
S
S
