So i found a really clean '96 Z34 so i went to war on it.. Looks like im the first person to rape it lol....
* '96 ECU
* PCM box/tray (already have it installed )
* Upper intake manifold w/ intake pipe/TB/all sensors/throttle cable bracket
* Lower intake manifold
* fuel rail
* windshield cowl (my was trashed... already installed)
* headlight (mine was cracked)
i thought about pulling the heads and other stuff but didnt want to spend any more $$. I read the write up about the intake swap, looks like i will have to go back and grab the:
# ’96 Throttle Cables (This is debatable, ‘92 will work with some modding, but the cruise cable will NOT
# ’96 Coolant pipe that runs from the water pump junction across the front of the motor to the lower intake.
# 96 Rear Cam Carrier Cover (Valve Cover)
how hard is it to remove the throttle cables?
Im curious to see what kind of a difference the newer intake will perform with my turbo setup... Hopefully it all fits in pretty nicly w/o to many modifications.. Any of you turbo guys running the newer style intakes? what do you think? it does look tremendously different inside then the old style.. much more open and no snail shell to breath threw
S
* '96 ECU
* fuel rail
S
