Small update.. Started working on my stand alone the other day. Had redo the factory work, (did'nt like the workmanship) and lengthen the overall harness. I'd picked up the properly labeled wires a while back. The wires have label of where they go written into their coatings. Makes life a little easier for the installer (me).
This is the original set up. There was nothing to support the wires where they entered the ECM plug. Looked like a weak spot to me.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image14.jpg)
This is after I removed the factory crap covering.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image11.jpg)
I desided to wheather proof the 2 areas @ the factory crimpings for added strength and protection with heat shrink tubbing.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image12.jpg)
Now a bundling layer @ the base of the plug and running down about 8 or so inches.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image9.jpg)
Next I soldiered the wire ends to their corresponding wires..
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image10.jpg)
Heat shrinking each of them aswell.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Harness003.jpg)
Then using a long length of heat shrink tubbing, I covered the harness to about 2/3 the total length. As you can see I also fused the cable to the plug for added harness durability @ the plug end.
![](http://i614.photobucket.com/albums/tt221/Smittro1/Image8.jpg)
