air intake
  • #16
    okay now only if i could find an filter adapter
    • #17
      Air intake tubing couplers for cold air intakes, turbo or boost pipes and more at Summit Racing.
      there's a few out there...
      EDIT:
      Free Shipping - Spectre Performance Reducer Couplers with qualifying orders of $109. Shop Tubing Couplers at Summit Racing.
      exact one... for a 3" to 4" transition... not as smooth of a change as i would like, but its not bad.
      • #18
        oh thats all i need. i can get those at autozone. i was under the impression that i would need something hard to clamp a filter to, and silicone reducers wouldnt work
        • #19
          the short section of 4" pipe..... that would go on one side with the filter attached, the 3" on the other side...
          • #20
            oh okay
            • #21
              okay well size problem solved. i went to lowes as im just making a cheap one out of abs pipe, and i found out it is 3in on the inside but is 4in outside so perfect, and everything for less than $20 ftw
              • #22
                wow, jake way to ghetto the nicest cutty i've seen in a long time
                • #23
                  LOL i will do a proper one once i have a job this is just going to be a temp intake (6 or so months) i am going to paint it gloss black and use some stainless steel couplers so it should look decent
                  • #24
                    or i may just suck it up spend $50 and do it right the first time
                    • #25
                      people please help talk me into getting a real intake
                      • #26
                        if you don't
                        • #27
                          LMAO
                          • #28
                            okay who knows the best way to build a dohc intake
                            • #29
                              You could keep it simple and get one of the "warm air intakes" on ebay. Now people are starting to claim true CAI going into the fenders cause a car to run slower because of all of the bends in the pipe. A WAI just comes off, turns enough to go where the stock filter was, and there is your cone filter.
                              • #30
                                I still stand behind CAI is better. My car looses all kinds of power and runs hot as hell with a WAI.
