bottom end troubles
  • bottom end troubles
    so i got my crankshaft...i go to put it in..... thrust bearings went in hard...crank won't spin without more than 60 fottlbs ....wayy to much
    caled the company sending me a new one....they either sent the wronge bearings with it or didn't machine the thrust surfaces enough
    yet another week of waiting..heads are done though
    does ne one know the difference between 3.1 and 3.4 main bearings.. supposedly they arre interchangable but i found info at my work and the 3.4 are alluminum or softer, the cranks are the same rite?
    vrrrooooooooooooooooom i need new exhaust
    cranks should be the same, they have the same part number
      cast numbers are the same part numbers through the dealer are diff
        some are yes, but not all.
          what did the plasti guage tell you? You did use it right?
          2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
