Just a couple more observations.
The cam timing on the DOHC is set for a powerband of around 3.5-4k to 6.5k. Since I had the misfortune of picking a small turbo I got to experience boost at 1k if I wanted. The verdict: the engine still doesn't "kick" in till 4k, below that it is a tad torquier then NA but for the most part all it does is make a lot of noise. Once 4k hits it pulls like a mofo.
Now for Getrag vs auto. The stock stall is high enough on the 4t60e that the engine RPM's are rarely under 2k, for the most part simple driving around keeps you in the 2.5-3.5k range. On my 5spd I see 1.5k to 2k way too often, and most city driving is in the 2 - 2.5k range. (both examples assuming you don't beat on it)
Whats this mean? You can get away with a smaller turbo on an automatic car, the stall speed and torque converter keep the engine RPM's high enough that it skips the lack of power under 4k (the engine starts pulling a little sooner with the turbo, around 3.3k). With the 5spd it is pretty much utter hell trying to drive it. The turbo is spooled in normal driving and it feels like you are lugging the engine a good amount of time. It also feels a bit resistant to rev like it did NA.
In conclusion, if you have an automatic and looking for 6psi then go for an small turbo. If you have a 5spd and/or looking at more then 6psi then I suggest picking a turbo that will start spooling around 3k and be fully spun up at 4k.
And yes TimG, I should have listened to you way back when.
