I'm doing an OBD-II swap in the GTP this week. I've got the engine bay harness, and computer, from a 96 Monte Z34. What do I need to do to the interior harness for this swap? Can I just repin the C100 and change a few things on the diagnostic connector, or do I HAVE to swap in the OBD-II Interior harness? I'm in the middle of a 5-speed swap too, so I've already got the interior gutted.
1994 OBD 1.5 to OBD II
Actually... this would really belong better in the computer related forum... Feel free to move this, mods.1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
1995 BMW 540i, Alpineweiss-III, 6-Speed
1995 BMW 540i, Schwarz-II, Automatic
2004 Honda 919, Light Silver Metallic, 6-Speed
He *should* be able to plug in a 97 ECM later once he gets it all going I would think.sigpic New 2010 project (click image)
Maybe he only had access to a 96 car to pull the stuff for the conversion at the time?sigpic New 2010 project (click image)
D.O.H.C. has a '94 z and did a '96 swap. you shouldnt have to do anything to the interior harness. all the changes are on the engine harness. you will most likely have to bypass the "passkey" because the '94s don't have the chiped key.
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Originally posted by IsaacHayes View PostMaybe he only had access to a 96 car to pull the stuff for the conversion at the time?
Originally posted by RedZMonte View PostD.O.H.C. has a '94 z and did a '96 swap. you shouldnt have to do anything to the interior harness. all the changes are on the engine harness. you will most likely have to bypass the "passkey" because the '94s don't have the chiped key.
S1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
Great prices.
The 96 and 97 harnesses are very similar. The biggest difference seems to be the transmission (though I would have to take another close look at the specs to be sure). The interior harness shouldn't need work except for the OBD2 connector. You will need to rearrange some of the C100 pins.
I made a spreadsheet for this swap a while ago, but still haven't done mine.
RedZMonte has done this swap.
Tim1995 Z34 - T04E "60" trim, 42.5 lb/hr injectors, AEM WBO2, FFP UD&DB, 3" exhaust, 2800 stall, shift kit, tranny cooler, Powerslot, Hawk HPS, rear disc conversion, KYB, Eibach, HMS F&R STB, Fittipaldi Force 18" wheels, big stereo, lots more coming eventually...
325 whp 350 lb-ft
Originally posted by mrl390 View PostIf you get a 97 ECM, it will be set up for the 4T65e. If you have a 4t60e in your car then I cant see how the 97 ECM will work for you. Maybe for the engine control but not for the transmission. Correct me if Im wrong.
Originally posted by bve32k View PostThe 60-E came in the 96's and then in 97+ 3100 cars. 97 3.4L DOHC Monte came with the 65-E.
is there a problem with that?
