3.4l dohc procharged
  • 3.4l dohc procharged
    I have a 95 3.4l dohc with these mods
    p1sc 7psi superchager intercooled
    2 core hd 16" radiator
    light weight lifters
    mag wires
    ac delco plugs
    msd 2 post coils
    38 lb injectors
    3000 stall
    rebuilt tranny
    full ported everything
    underdrive pulley
    here is my problem I had the car finished and have ran it couple times but the old modified fuel pressure regulator took a crap. now the air fuel mix is off with the stock one.
    I need to get it down to Indiana. I don't have anything to tow it with, and I can't buy another modified fuel pressure regulator cause that was a one time deal and it ran a little to rich. I went to go drive it with the stock fuel pressure regulator and I was gunna start with a new fuel rail set up so i can get an adjustable one but done no where to start with i don't have my machinist tools anymore (aka got laid off no work). iIt will die and I'm not gunna mess it up by starting it lean. what you guys think. I need to get down to indi to get my computer tuned, should I just bypass it and put the stock intake back on and let the sc run freely or should I make a new fuel rail, one that will support an adjustable fuel pressure regulator for my car.
    Your stock should be able to run it no problem. I'm running 8psi with 42lb injectors on stock reg and stock fuel pump. It ran real rich till I tuned it out. T
