Hey im having some trouble deleting the pcv system and evap. First of all i know ill have to delete some codes from the pcm. But yeah basically all i need to do is remove all the components, cap off the vacuum lines and add breathers to the valve covers right?
Heres a vacuum diagram.
![](http://img.photobucket.com/albums/v234/gpchris/wtff2.jpg?t=1240889528)
Also should i remove the vacuum line from the tb to the valve cover? Its actually pre TB vacuum.
